Home > General (L461) > Buzzing noise when vehicle moving from Drivers Door
Rowdie
Hi. Hope someone can help. I have started noticing a buzzing type noise (sounds electrical, or motor) Intermittently from the front drivers door when moving as reasonable speed. Have anyone else had this. Nothing has stopped working, and I cannot replicate it when stationary. Its not a air leak type whistle, and is always the same pitch, i.e.. it does not change pitch with speed
Any ideas please ? I am terrified or allowing dealer to take the door apart, but its really a bit annoying now !
P460e Hybrid
Post #641038 Mon Apr 08 2024 2:31pm
rsr
I have something similar started recently, I don't think mine is electric as when I put force on the upper door card it goes away. Very annoying though.
Post #641044 Tue Apr 09 2024 2:05pm
Rowdie
I will give it a try. Do you think it’s a vibration then ???
Post #641053 Tue Apr 09 2024 5:41pm
Rowdie
Vibrating buzzing noise
Hi RSR, where on the door card are you pressing I have tried and cant make it stop. Below the material line at the top ?. I still cant find out what's causing it. Is yours only doing it whilst moving at medium speed ?
Post #641449 Wed Apr 24 2024 12:44pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Mine vibrates also but when I press on the handle it goes away. Only at slow speed and over non smooth roads.
Post #641469 Thu Apr 25 2024 6:51am
rsr
Re: Vibrating buzzing noise
Hi Rowdie
Mine does is at different speeds, it's more noticeable on bumpier roads which is most of the time nowadays! If i press in the area in the image it tends to stop.
Post #641471 Thu Apr 25 2024 7:18am
Rowdie
Thanks RSR
Post #641668 Thu May 02 2024 11:49am
JDPRRSUK
Mine going in to dealer for door card removal to investigate. Something vibrating in there as doesn’t happen with other doors.
Post #641683 Thu May 02 2024 10:54pm
Rowdie
if anyone gets any useful info on what their noise is, please could they post it here ? Would be really grateful to have some guidance before it goes in to the dealers.
Post #641785 Wed May 08 2024 9:55am
