![]() | Home > General > Power Steering Fluid Change |
I recently started option 1. I extracted fluid from the reservoir, filled with new, started the car and turned the steering wheel lock to lock a few times. Shut off the car, and repeated the aforementioned about eight times. I got about three reservoir refills per liter. My fluid was black when I started, it’s now moved to a transparent brown. Figure I’ll repeat the same process when I do the rear wheel bearing that’s starting to sing me the song of its people.
Just do option 2. Disconnect a pipe low down.
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 166 ![]() ![]() ![]() |
Eh up
Eh up Col
Eh up all,
Haven't got around to it yet, but have a spare reservoir cap here which I was going to fit to a 5 liter container to, then fit that in place of the existing cap temporarily to in effect make a 5l reservoir to fill with fluid, then remove return hose and feed it into a container, blank the reservoir return and bleed as per w/shop manual, hopefully be able to change fluid all in one go without the reservoir running dry. Not sure if it will work or not, only one way to find out I guess.
TTR. I would just keep it simple. Let gravity do its thing.
Eh up
Eh up all
The small straight outlet on the bottom of the reservoir is the return, the larger angled one is the suction feed supply to the pump.
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 69 ![]() ![]() ![]() |
This bloke's method seemed to do the trick OK:
Eh up all
The first few pulls on mine were also a nasty black, almost used diesel oil black.
