Home > General (L494) > Warranty Knock Back - Dynamic Suspension Failure 2014 L494
Disco_Mikey
Usually, part failure due to corrosion is excluded
MOT warranty does not (unless things have changed recently) Thumbs Up
Post #640820 Sat Mar 30 2024 5:37pm
Imac819
Just following up on this Raven8080 did you get the same goodwill gesture of 40% off the cost of replacing the front ACE pipes that Paulo did? I currently have the same issue and have taken it up with Pentland In Stirlingthat the warranty is very vague with regards the corroded pipes in this system!
Post #640980 Fri Apr 05 2024 8:05pm
