Home > My Range Rover Sport > 2021 P400e Autobiography Dynamic
Page 1 of 3 123>
SpiderPig
Picked this up today and delighted so far!
My fourth LR after a FL2, L322, and an Evoque.
I’ll update this thread with likes/gripes as I find them. Probably makes a bit of a change here to have something a bit modern…
Post #640421 Thu Mar 14 2024 8:19pm
Lindab
Thumbs Up Thumbs Up Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #640423 Thu Mar 14 2024 10:35pm
SpiderPig
First impressions after a few days ownership.
It's a rather lovely car to drive, it's a relaxing slipper-like drive - nothing like the immediacy and nimbleness of my old Volvo (which seems a weird thing to say about a Volvo, I know). However, for all of the waftiness, cars in the rear view mirror do disappear effortlessly.
I've somehow managed to get all of the connectivity working, so it's all set up with the app, CarPlay, and even sending routes to the car works (despite the app being two years old and a raft of 1 star reviews).
Some things not so good:
* The only way to fold the backs seats down is to move the front seats forward. I'd looked at other cars where the back seats fold down with a button in the boot. But with the RRS, all five doors have to open to get the back seats down.
* There's no automatic "hold" brake on stopping at junctions/traffic lights. I have to either hold the brake or engage the parking brake.
* The somewhat lazy moving off from a standstill (especially pulling out of junctions or entering roundabouts etc, when you need a bit of speed to clear effectively). I know this is probably the stop/start at play, but this is a hybrid - there should be electrical power on tap to get you moving.
Post #640495 Mon Mar 18 2024 10:36am
jimbg
yes, should move away quickly as using electric motor when crawling or pulling away.
Does the car run fine in pure EV mode without the engine starting? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #640497 Mon Mar 18 2024 11:56am
SpiderPig
To be honest, not tried pure EV mode yet (keep forgetting to press the button).
There's been times when the pull-away has been fine, so maybe there's a reason for some of the slow up-takes.
I'll keep an eye on it.
Another bit of annoyance is the car showing "Initialising" when at 100% charge (using a three-pin). The salesman seems to think this is normal, but I'm no so sure at all.
Post #640498 Mon Mar 18 2024 12:00pm
jimbg
Do a test in EV mode, there is a common problem with the battery heater and if you have that then you will not be able to run in EV mode without the engine starting.
No, it should not be stuck on initialising, but is a bit of a bug.
If you unlock the car and lock the car either the usual way or via the app, it should clear.
But do check out your car in pure EV mode! 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #640499 Mon Mar 18 2024 12:06pm
SpiderPig
Just tried EV mode on a moderate journey - 25 miles of country A and B roads
Very impressive average of 189 mpg.
Post #640504 Mon Mar 18 2024 1:48pm
jimbg
A little bit of engine then! Pure EV records as 250+ mpg! Rolling with laughter 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #640505 Mon Mar 18 2024 2:45pm
SpiderPig
Yeah, ran out of juice about a mile from home. It also engaged the engine for a bit after emerging from junctions.
It really doesn't like upward inclines in EV mode either. It'll do them, but slowly.
Post #640506 Mon Mar 18 2024 2:50pm
Lindab
They take off in second gear. Know the feeling well, no power then you automatically press the accelerator harder then it picks up. Use the paddles Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #640514 Mon Mar 18 2024 4:48pm
jimbg
The hybrid should be using the electric motor, mine certainly does. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #640515 Mon Mar 18 2024 5:06pm
SpiderPig
Is this boot alignment normal, or does this need to be corrected? I saw the same dropped boot on my Evoque and had it raised to line up.
Post #640517 Mon Mar 18 2024 6:22pm
SpiderPig
I manged to get the charging to complete properly now.
I unlocked and locked the doors using the app mid way through charging and that seemed to have done the trick. It could be that the fault/bug with the car has also sorted itself out. But at least I don't have the worry of the battery deteriorating from the constant "initialising".
Post #640540 Wed Mar 20 2024 8:21am
SpiderPig
Charging has gone back to showing "Initializing" again at the end of the charge cycle. At least it charges up all the way before it does that though. Unlocking/Locking the doors doesn't do anything in this state as the charge unit itself is in an error state.
The artificial engine sound must be the worst engine sound I've ever heard. I'd dearly love to turn it off. 2021 P400e Autobiography
Post #640604 Fri Mar 22 2024 10:32am
jimbg
What artificial engine noise? I only have the real one! 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #640610 Fri Mar 22 2024 12:24pm
Page 1 of 3 123>
