![]() | Home > My Range Rover Sport > 2021 P400e Autobiography Dynamic |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 923 ![]() ![]() |
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 124 ![]() ![]() |
First impressions after a few days ownership.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1878 ![]() ![]() |
yes, should move away quickly as using electric motor when crawling or pulling away.
To be honest, not tried pure EV mode yet (keep forgetting to press the button).
Do a test in EV mode, there is a common problem with the battery heater and if you have that then you will not be able to run in EV mode without the engine starting.
Just tried EV mode on a moderate journey - 25 miles of country A and B roads
A little bit of engine then! Pure EV records as 250+ mpg! |
Yeah, ran out of juice about a mile from home. It also engaged the engine for a bit after emerging from junctions.
especially pulling out of junctions or entering roundabouts etc
The hybrid should be using the electric motor, mine certainly does. 2023 P440e SE Dynamic on order -cancelled
Is this boot alignment normal, or does this need to be corrected? I saw the same dropped boot on my Evoque and had it raised to line up.
I manged to get the charging to complete properly now.
Charging has gone back to showing "Initializing" again at the end of the charge cycle. At least it charges up all the way before it does that though. Unlocking/Locking the doors doesn't do anything in this state as the charge unit itself is in an error state.
What artificial engine noise? I only have the real one! 2023 P440e SE Dynamic on order -cancelled
