Home > General > EAS is it possible to force top up ? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
If the question is, how do I raise the suspension without starting the engine, this will tell you how, via the key.
Sat Mar 16 2024 12:10pm |
loonyball Member Since: 29 May 2019 Location: ballymena Posts: 30 |
hi andy, thanks for the quick reply, yes i can start the engine ok, my problem is because there is an issue with the low/high range actuator on the transfer case, its preventing the HDC and special programs from working and in turn stopping the suspension rising, if i could get the suspension raised to enable me to get to the transfer case actuator i'm pretty sure i could solve the problem.
Sat Mar 16 2024 1:20pm |
just to update, i removed the transfer case control module and due to water ingress its fried, so, new module, programme to my car and keep the fingers crossed. |
Sat Mar 16 2024 3:33pm |
I’m slightly surprised it stops the air suspension.
Sat Mar 16 2024 3:36pm |
