Home > General > EAS is it possible to force top up ?
loonyball
United Kingdom 2007 Range Rover Sport TDV6 HSE Rimini Red
good afternoon every one, i have an issue with the transfer case actuator, my problem is the EAS has completely deflated (due to the HDC fault caused, i hope, by the green blinking hi/low range issue)
anyway, i need to get the car height back up to gain access to the transfer case actuator, my question is, is it possible to force the EAS to re-fill or top up manually ??
2006 RRS 2.7
thanks.
Post #640443 Sat Mar 16 2024 12:47pm
If the question is, how do I raise the suspension without starting the engine, this will tell you how, via the key.
?si=a38fBFbCmkeMEK6h
If the red suspension light is on and that's the problem, jack the up a bit, and then try and start the engine
Post #640444 Sat Mar 16 2024 1:10pm
loonyball
hi andy, thanks for the quick reply, yes i can start the engine ok, my problem is because there is an issue with the low/high range actuator on the transfer case, its preventing the HDC and special programs from working and in turn stopping the suspension rising, if i could get the suspension raised to enable me to get to the transfer case actuator i'm pretty sure i could solve the problem.
thanks
Post #640445 Sat Mar 16 2024 2:20pm
loonyball
just to update, i removed the transfer case control module and due to water ingress its fried, so, new module, programme to my car and keep the fingers crossed.
Post #640448 Sat Mar 16 2024 4:33pm
I’m slightly surprised it stops the air suspension.
Run engine
Close doors
Press suspension up, should make it rise.
Post #640449 Sat Mar 16 2024 4:36pm
