![]() | Home > General (L461) > Timed charging on P440e |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1875 ![]() ![]() |
Check that it is still "ticked" in the car, I have had a problem for it occasionally to reset. 2023 P440e SE Dynamic on order -cancelled
Rowdie Member Since: 14 Jan 2015 Location: Uk Posts: 187 ![]() ![]() |
Hi. I have the opposite. It started charging at the start time, but just carried on after the end time untill I spotted it still charging hours later.
bimjim Member Since: 17 May 2010 Location: Hertfordshire Posts: 90 ![]() ![]() |
My low cost electricity window is long enough to fully charge the battery on mine, so I don't have that issue. However, I did have that problem with the iPace I had before. Although that was pre-Pivi Pro, it probably had similar quirks...
MikeJG Member Since: 30 Aug 2022 Location: Shropshire Posts: 65 ![]() ![]() |
Mine is the same and there is no rhyme or reason to it. Sometimes it stops and sometimes it carries on. I can find no circumstance that makes it more or less likely. I am just in the habit now of looking at my inControl App when I get up in the morning and pause charging if it is still going after the 7am end of cheap rate. Very Odd. L461 P460e AB |
you cant make it up can you !. I have had 2 good days where it stopped !
Not on Octopus and so I am not missing anything I didn't have. I am on EON EV rate which is not the cheapest night rate at 9.048p but it is the longest time on offer at 7 hours and that works best for me as I only charge off a 13A plug which gives me about 2.8kW or half a fill in the 7 hours. Usually enough for my daily running around.
Hi Mike. Will do, BTW I have a car that costs in excess of 100K and it failed again to stop the charge at the set end time last night !.
I think it is a very specific model and owner use case that comes up with this issue.
Likewise ! And copied what you did on the feedback mail to JLR in the app
Did you try setting a departure day/time a few days ahead, to see if that workaround does the trick? 2023 P440e Dynamic SE |
Thanks BigJim. I have tried it and it worked last night, so will see if it works over the coming weeks. Appreciate the workaround ! |
As you know the charging stops when you use the car.
That's good. It's slightly quirky, but it worked consistently on my old iPace. 2023 P440e Dynamic SE |
A little update on the issue of charging not stopping at the end of timed hours.
