Home > General (L461) > Timed charging on P440e
terrygill
Also have same problem of not switching on in low cost hours. It’s on 24my
All set on screen in car but phone app does not show the same hours as in screen
Post #644710 Sun Oct 13 2024 11:15pm
B McP
Scotland
I have a 2024 model P460E and am a Octupus customer on the EV rate system which is between midnight and 06:00hrs. I programme the charge via the Octopus AP not the car or the charger and it works every time. I set the amount of charge I want and the Octopus AP does the rest.
Post #644731 Mon Oct 14 2024 7:59pm
jimbg
What charger do you have?
Is it Ohme, Hypervolt, myenergi or Wallbox? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #644736 Mon Oct 14 2024 9:28pm
terrygill
Our is a 2024 460e too. We are also with Octopus and on the low rate, which in our area is 00:30 - 05:30hrs.
On the Octopus App you can select your vehicle but no Land Rovers are listed. You can choose a charger brand instead but that’s no good if you are just charging from a standard domestic plug
Post #644739 Mon Oct 14 2024 10:51pm
jimbg
You can still have an off peak tariff but you will just need to use the car to schedule it.
That's what I do and it works fine, they used to have Land Rovers listed but removed them after one of the security updates. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #644744 Tue Oct 15 2024 8:20am
B McP
Scotland
I have a MyEnergi Zappi and during the setup with Octopus through the AP I was able to choose this device and the model of car I have.
Post #644745 Tue Oct 15 2024 8:35am
jimbg
Yes, now it's the EV charger controlling it, when I signed up 3 years ago the Sport was recognised and worked fine. Did you not get the email from Octopus informing you the Sport was off the list? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #644747 Tue Oct 15 2024 9:41am
B McP
Scotland
I switched to Octupus approx 3 months ago and set my car and charger up in the Octopus AP then. The Octopus AP is the only control mechanism I use to charge the car. As soon as I plug the car in, I get a message through the Octopus AP that outlines the charge times and they are within the EV low cost window.
Post #644748 Tue Oct 15 2024 10:23am
jimbg
Okay, you joined just as they dropped JLR support, but you have one of the 4 supported chargers so are good to go. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #644749 Tue Oct 15 2024 11:31am
