![]() | Home > Maintenance & Modifications > Correct engine oil question |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 421 ![]() ![]() ![]() |
Am going to get my boroscope out and see if I can poke it down the cover to have a look. Always listen to old people or when they die you will live on in ignorance.
Failures have been noted across all MY's, with 07/08MY most prominent |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
Thank you all for the advise. I guess I can go fwd with this then. |
Always remove the filter first
Hi DM,
The suction vacuum is created in the extraction tool you are using, not the engine, so will not make any difference if the filter is refitted first or not.
As above |
I have had mine overfilled by a dealer before now, did you allow the engine to cool before you checked it? after 10,000Km's I don't think you will get any joy from a Stealer, just change it and fill with the correct quantity and grade, also after 10,000 Km's if you were going to do any damage I would have thought it would show and have been done by now. Just measure the quantity you remove to compare if it was a excessive or minimal amount. Are you also saying that is the first time you have checked your oil in 10,000Km's?
Hi Col,
Oddly you’re supposed to check the oil level with the engine warmed up. It’s also usually best to change oil on a warm engine so anything in the oil is suspended and gets drained.
I finally did today the oil change with the extractor. |
