Home > Technical > Multiple Yellow warning light illuminated at once |
Datsun770 Member Since: 27 Feb 2024 Location: Ayrshire Posts: 5 |
Oh and I should say I considered ride height sensor being a cause as the front left wheel does always seem higher than the rest on the display, ever so slightly but no codes for this on the scan at all. I do also have to confirm ride height when I start vehicle after the errors are thrown up and the ride drops to access height when the errors are thrown but returns when started. Some mornings I hear the cinoressor kicking in for a minute, but figured that was normal. Again another reason I thought maybe battery dying or something causing a drain or lack of charge.
Thu Mar 07 2024 5:23pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Earth points in front wheel arches
Thu Mar 07 2024 7:20pm |
You reckon?
Thu Mar 07 2024 7:26pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 536 |
Fri Mar 08 2024 10:00pm |
To be fair he seems to have at least done that as thisnwas the mode it was in when it was ready albeit I expected it to be in jacking mode.
Sat Mar 09 2024 6:35am |
