![]() | Home > Technical > Multiple Yellow warning light illuminated at once |
Datsun770 Member Since: 27 Feb 2024 Location: Ayrshire Posts: 5 ![]() ![]() ![]() |
Oh and I should say I considered ride height sensor being a cause as the front left wheel does always seem higher than the rest on the display, ever so slightly but no codes for this on the scan at all. I do also have to confirm ride height when I start vehicle after the errors are thrown up and the ride drops to access height when the errors are thrown but returns when started. Some mornings I hear the cinoressor kicking in for a minute, but figured that was normal. Again another reason I thought maybe battery dying or something causing a drain or lack of charge.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Earth points in front wheel arches
You reckon?
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 554 ![]() ![]() |
To be fair he seems to have at least done that as thisnwas the mode it was in when it was ready albeit I expected it to be in jacking mode.
