Home > General > More electrical wiring woes on my 4.2 Supercharged
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Another job ticked off the list it's amazing how many people remove the trim break the clips and refit without fitting new clips.
Post #640110 Sat Mar 02 2024 11:33am
Markieboy123
United Kingdom 2005 Range Rover Sport Supercharged Stornoway Grey
Crazy for a couple of quid and 5 mins work.
Next stop leaking air suspension, suspect NSF AIR STRUT
Post #640111 Sat Mar 02 2024 12:17pm
JonnyCJ
The front valve block is a little trickier than other non 4.2s as there's an aux radiator in the way.
If you want to eliminate the valve block, you can see it through the plastic grille in the bumper (offside front bumper located).
Spray some soapy water around the pipe connections you can see. That should hopefully make life a bit easier.
Otherwise, if it's a leaky strut the old fuse 3 is your friend.
Post #640249 Fri Mar 08 2024 10:29am
