Home > Maintenance & Modifications > How much for a replacement front windscreen? |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 80 |
My last windscreen replacement still comes up on my renewal list, but hasn't incurred a penalty. |
Sun Feb 18 2024 10:53am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Without actually asking the insurance company I don't have a definitive answer if it will attract any loading, but again maybe different companies have different views.
Sun Feb 18 2024 11:04am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
Things may have changed since last year, but I have never had to declare a windscreen claim on any comparison site. Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
Sun Feb 18 2024 11:25am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
I don't think a windscreen will change your NCB, so I would claim.
Sun Feb 18 2024 11:48am |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 538 |
Had mine done at Carglass and asked them to order OEM LR which they did. SW
Sun Feb 18 2024 2:30pm |
looking at the documents, it seems Autoglass is used by my insurers.
Sun Feb 18 2024 2:54pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Autoglass don't do Pilkington. They do some cheap thing from, I think, South Africa. You can try to get them to fit Pilkington but I wouldn't hold your breath.
Sun Feb 18 2024 3:13pm |
Thanks for that, sounds about right. I suppose I should also speak to them so they know that its tinted, heated and has auto lights/wipers |
Sun Feb 18 2024 3:19pm |
They fitted new A pillar black covers. |
Sun Feb 18 2024 3:46pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 528 |
Old and confused,
Sun Feb 18 2024 4:31pm |
From my experience, Autoglass won't fit OEM (Pilkington) on older cars - OEM on young stuff still likely in warranty.
Sun Feb 18 2024 4:50pm |
Carglass just took the code of my old windshield, so all options were copied.
Sun Feb 18 2024 5:05pm |
Thanks guys, I'll sort it out with Autoglass. |
Sun Feb 18 2024 5:37pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
If it's a L320 it won't have ADAS so not a problem, they will have to remove both inner and outer pillar trims, as well as the lower windscreen scuttle panel, unless they replace the outer pillar trim make sure they renew the clips as there is a strong possibility the will break them when removing the trim, if not you will get wind noise, a rattle or loose the trim going up the road. Also make sure they refit the scuttle correctly otherwise you may get water in through the fresh air vent.
Sun Feb 18 2024 8:50pm |
