Home > General > Service Required Message
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up all,
Whilist actually getting a bit of dry weather I did a clean on the car this weekend and took it for a drive.
On start up I noticed a small message on the dash service required which then quickly disappeared šŸ¤”
I know/ allegedly it had a full service just before I bought it, and having immediately checked a few things when I got it last year it looks like it had, as all service parts were newšŸ‘
So my logic is that itā€™s just not had a service reset or Iā€™m missing something here .
Iā€™ve not got access to a code reader ā˜¹ļø
Can anyone tell me if this is just a standard message that simply needs a reset or what it may be.
Also on my lady BMW X5 I could manually reset using a sequence of dash and button presses, is the same possible as I want to remove the message
Iā€™ve read a few bits on here but not sure if it works for a facelift l320 sdv6 on a 2012 plate
Cheers for any help as usual
Post #639614 Mon Feb 12 2024 7:37pm
NoExpert
Itā€™s the oil change reminder and needs to be reset with diagnostics, regardless of what others may say. There are two different things to reset, service timer and oil life. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639615 Mon Feb 12 2024 7:41pm
TTR
Eh up No Expert šŸ‘
Mmm I was dreading hearing that , means a trip to a garage and no doubt a few notes to do very little ā˜¹ļø
They clearly forgot to re set the timer - Ivevdone less than 2000 miles since it was changed, unless of course itā€™s telling me my oils not in great shape which is a different concern, but if I understand itā€™s either time or miles it will work on. please correct me where Iā€™m wrong.
I assume itā€™s a case of using a coder and simply resetting a date .?
Cheers for any more information on this - it all helps, least itā€™s nothing too concerning šŸ‘
Post #639616 Mon Feb 12 2024 7:50pm
NoExpert
Itā€™s based on mileage and/or oil dilution (calculated by DPF regens). This is why two different things need to be reset.
Definitely need the correct diagnostics tool to reset both. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639617 Mon Feb 12 2024 7:53pm
TTR
Eh up no expert
Just a thought- if Iā€™m doing short journeys then if the regen is kicking in and because Iā€™m doing short runs have I read it might be affecting oil dilution hence could be a contributing factor
I never realised it would read condition, so got me thinking
If thatā€™s the case what do people run oil wise 5w30 or 5w40 fully synthetic, does it help at all maintaining oil condition
I will change the oil and filter to be on safe side once the codes read, I appreciate how important this is to engine condition
Cheers all
Post #639618 Mon Feb 12 2024 8:21pm
Stevepd
https://www.rrsport.co.uk/forum/topic54933.html
Hope this helps. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #639619 Mon Feb 12 2024 9:00pm
TTR
Eh up stevepd
Thanks bedtime reading šŸ‘
Post #639620 Mon Feb 12 2024 9:04pm
NoExpert
Only 2000 miles, they didnā€™t reset it. Possibly didnā€™t reset it the time before either. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639662 Wed Feb 14 2024 4:45pm
TTR
Iā€™m a bit more relaxed thatā€™s itā€™s simply just a reset rather than a dilution issue
My toes curled when I read that šŸ˜
Iā€™ll drop the oil - Iā€™m thinking of doing it via the extraction tube, never tried that before as always felt better to do through sump plug but having read the access and proximity to cross member I donā€™t fancy a 5w30 oil shower šŸšæšŸ˜‚
From the reading on here the top extraction pipe goes right to the bottom of the sump so minimal residue left in sump - unless Iā€™m wrong in which case please correct me.
Cheers in advance
Post #639672 Wed Feb 14 2024 8:18pm
NoExpert
Correct, extraction tube is about the same height as the drain plug so you get nearly everything out of it.
The extraction tube makes an oil change an easy and clean job to do. Just have to make sure everything gets reset. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639685 Thu Feb 15 2024 10:42am
TTR
Eh up
Firstly thanks No Expert for confirming šŸ‘
All
Well interesting message today on car which is concerning me and I think may be linked to this post šŸ˜³
Mrs ran it today started fine usual message Service Required, drove it 18 miles parked up
Re started and was fine, then drove a mile and got Restricted Performance and Red Triangle , she pulled it straight up after 1/2 mile and said it ran fine but knew she needed to stopšŸ‘
Rang me, she turned car off, then re started, restricted message appeared briefly after car started then disappeared only then got Service Required message back up. She ran it home 16 miles no problem.
I got home tonight and checked :-
Oil level which is a mark or two of max, after 3 hours stood still
Service Required message was only message to flash up when I started it
Thereā€™s no message or info in the menu to suggest any other issues
Is this related to the oil needing changing and the fact itā€™s nearly at its max level when effectively cold
I am going to do the oil and filter asap, question is can I run it in the interim ?
Itā€™s going to be a week or so before I can get it to an Indy to reset the service message and try to see if any fault codes re the Restricted Performance pop up
All input grateful received as always
Post #639701 Thu Feb 15 2024 8:19pm
Karlp606
Sounds either DPF is getting clogged up so you need to drive it above 50mph for about 20-30 mins at above 2000rpm to clear it.
Or if you have a code reader stick the code reader in, I had the same issue with the RP was clogged MAF sensors. Could be that but best to check the code.
I dont think the service interval message and this issue is related.
Post #639715 Fri Feb 16 2024 12:46pm
TTR
Ehup Karlp606
Thanks for the views, am going to drop oil first, then get it code read
Might take me a week or so but I will update this postšŸ‘
Post #639720 Fri Feb 16 2024 7:26pm
Karlp606
Get a cheap code reader from Amazon - next day delivery and it will help you if thereā€™s a code stored
Post #639722 Fri Feb 16 2024 8:52pm
Karlp606
Iā€™ve got a code reader but based just outside of Hull matey
Post #639723 Fri Feb 16 2024 8:53pm
