Home > General > Lights
nikster
Isle Of Man 2006 Range Rover Sport TDV6 HSE Java Black
Lights
Hi
when i turn the indicator on, an aux light comes on from the side light area of the lights, is this normal
thanks
Post #63774 Thu Oct 26 2006 5:24pm
Well only with Adapted xenons RRS TDV6 Gone but still around
Post #63777 Thu Oct 26 2006 6:03pm
landroverstormer
England 2006 Range Rover Sport TDV8 HSE Java Black
Late 06 models have the side projecting bulb but with the adaptive headlights. I noticed it on an HSE in the summer and found that it had been added to the standard spec without anyone promoting it! Razz I'm such a geek! TDV8 HSE in Java/Ebony with Zebrano Wood, RSE, Hybrid TV, and a few other bells and whistles.
Discovery 1 V8i Auto (The Off Road Toy)
Post #63791 Thu Oct 26 2006 7:08pm
nikster
so how can i tell if i have adaptive lights
cheers
Post #63905 Fri Oct 27 2006 7:14pm
tf9
Russia 2006 Range Rover Sport Supercharged Java Black
cheers
Try turning wheel infront of some wall in the dark Smile You will see. 2014 Mercedes-Benz S500
2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony
2013 BMW 530d
2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Post #63921 Fri Oct 27 2006 7:47pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
When you first switch them on, AH perform a little checkup "dance"... That's pretty much the only cool thing about them! Laughing Seriously, I find adaptive headlights to be most useless and overhyped technology. I wouldn't miss them if they took them away tomorrow. In the US, where adaptive headlights are standard equipment on most trims, some have complained the headlights shake and vibrate quite badly over bumps and broken pavement, disturbing oncoming traffic (I noticed the vibrations myself, although I don't find them that extreme.) I am guessing that is not a problem with fixed xenons.
Post #63925 Fri Oct 27 2006 8:22pm
umbertob
I don't think the headlights "turn" if you are stationary - at least mine don't. I have to be moving.
Post #63926 Fri Oct 27 2006 8:29pm
Singletrack
Belgium 2006 Range Rover Sport TDV6 HSE Java Black
The little "checkup dance" is a Xenon feature - the self leveling cycles through to the correct aim height. The vibration you describe is definitely not a problem with the fixed Xenons and I agree...I see no benefit from the adaptive headlamps - the RRS regular Xenons provide ample light as it is.
You can tell if you have adaptive lights if there is sort of a swivel mechanism to the lamp housing. The regular Xenons don't have this.
Finally - the illumination of the side projecting lamp when turning also occurs with the regular Xenons as I have (MY06). This feature is not unique to the adaptive lamps.
There are two bulbs in the "parking light" housing (located at the bottom outboard of the lamp cluster). The lower bulb is illuminated at the "park" setting - the centre mounted but side projecting bulb, is illuminated when the turn signal is used and the headlamps are on. This is a white lamp and distinct from the actual turn signal lamp which is in another housing within the cluster. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #63939 Sat Oct 28 2006 5:37am
umbertob
In the US we don't have side approach lamps, I had them on my early 90's Mercury Cougar and miss them dearly... Forbidden by law. Apparently, a pedestrian got "blinded" by one of those cornering lamps when crossing a street a few years back and walked into another car, sued the manufacturer and won. Only in America! I'm sorry, but the "dance" of the AH xenons is far sexier than the fixed beams'... Smile Side to side, up and down, criss cross and back in place.
Post #63941 Sat Oct 28 2006 5:50am
Singletrack
Very cool! Very Happy 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #63942 Sat Oct 28 2006 5:58am
