![]() | Home > General > Lights |
Well only with Adapted xenons RRS TDV6 Gone but still around
landroverstormer Member Since: 22 Oct 2006 Location: Somewhere close Posts: 325 ![]() ![]() ![]() |
Late 06 models have the side projecting bulb but with the adaptive headlights. I noticed it on an HSE in the summer and found that it had been added to the standard spec without anyone promoting it! |
nikster Member Since: 23 Jul 2006 Location: Douglas Posts: 10 ![]() ![]() ![]() |
so how can i tell if i have adaptive lights
tf9 Member Since: 07 Jun 2006 Location: Moscow, Russia Posts: 643 ![]() ![]() ![]() |
Try turning wheel infront of some wall in the dark ![]() 2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony 2013 BMW 530d 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD 2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD 2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD. |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
When you first switch them on, AH perform a little checkup "dance"... That's pretty much the only cool thing about them! |
I don't think the headlights "turn" if you are stationary - at least mine don't. I have to be moving. ![]() |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
The little "checkup dance" is a Xenon feature - the self leveling cycles through to the correct aim height. The vibration you describe is definitely not a problem with the fixed Xenons and I agree...I see no benefit from the adaptive headlamps - the RRS regular Xenons provide ample light as it is. You can tell if you have adaptive lights if there is sort of a swivel mechanism to the lamp housing. The regular Xenons don't have this. Finally - the illumination of the side projecting lamp when turning also occurs with the regular Xenons as I have (MY06). This feature is not unique to the adaptive lamps. There are two bulbs in the "parking light" housing (located at the bottom outboard of the lamp cluster). The lower bulb is illuminated at the "park" setting - the centre mounted but side projecting bulb, is illuminated when the turn signal is used and the headlamps are on. This is a white lamp and distinct from the actual turn signal lamp which is in another housing within the cluster. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
In the US we don't have side approach lamps, I had them on my early 90's Mercury Cougar and miss them dearly... Forbidden by law. Apparently, a pedestrian got "blinded" by one of those cornering lamps when crossing a street a few years back and walked into another car, sued the manufacturer and won. Only in America! I'm sorry, but the "dance" of the AH xenons is far sexier than the fixed beams'... |
Very cool! ![]() |
