Home > General > Brake fluid question
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi folks,
Hope you all had a good Christmas.
I've noticed that my O/S rear caliper is sticking, so I'm going to replace it next week.
With regards to brake fluid, I'm assuming I should be using DOT 4 but should I be using normal or synthetic.
I use DOT 5 silicone fluid in my Triumph Stag and know that you shouldn't mix types.
What did LR use from new ?
Many thanks 2010 RRS 3.6 TDV8 HSE Galway Green
Post #638603 Sun Jan 07 2024 6:25pm
Dot4 class6
Post #638604 Sun Jan 07 2024 6:28pm
Jabba
Thanks Andy Thumbs Up 2010 RRS 3.6 TDV8 HSE Galway Green
Post #638607 Sun Jan 07 2024 7:16pm
Do not use Dot 5 fluid, either Dot 4 or 5.1, I used 5.1 when I did a complete fluid change as has slightly higher spec. than Dot 4.
Post #638609 Sun Jan 07 2024 9:16pm
Jabba
Thanks Col Thumbs Up 2010 RRS 3.6 TDV8 HSE Galway Green
Post #638614 Mon Jan 08 2024 9:18am
Jabba
Would Ford wss-m6c65-a2 be ok to use
https://www.msds.ford.com/cpc/productDetai...RNo=189224
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #638615 Mon Jan 08 2024 9:40am
Yes
Post #638617 Mon Jan 08 2024 10:29am
Jabba
Thanks Andy 2010 RRS 3.6 TDV8 HSE Galway Green
Post #638618 Mon Jan 08 2024 10:35am
