![]() | Home > Maintenance & Modifications > Suspension codes after hitting standing water |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
You got your air pump wet clearly says exhaust valve try pulling out the pump and giving it a service. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9058 ![]() ![]() ![]() |
The exhaust tube has possibly got water or muck in it and it's stopping the system from releasing air. The exhaust goes via a silencer and then back to discharge inside the acoustic box that the compressor sits in. Taking off the cover and having a look to ensure the exhaust is free of crud wouldn't hurt as a start. Then check connections, etc..
