Home > Maintenance & Modifications > Suspension codes after hitting standing water
mark8815
United Kingdom 2005 Range Rover Sport TDV6 SE Rimini Red
Not sure if the 2 are related, but it happened the morning after.
Just before Christmas driving over the moors in the dark, out of nowhere ploughed into some standing water and set sail temporarily. Day after that I got the attached codes, car doesn’t lose height but I also can’t adjust height either. Get the amber warning light on every drive, if driving in rain I get the red one too which switches back to amber almost immediately so I’m presuming water is some sort of trigger.
Any ideas?
Post #638527 Wed Jan 03 2024 8:39pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
You got your air pump wet clearly says exhaust valve try pulling out the pump and giving it a service.
Post #638528 Wed Jan 03 2024 8:42pm
The exhaust tube has possibly got water or muck in it and it's stopping the system from releasing air. The exhaust goes via a silencer and then back to discharge inside the acoustic box that the compressor sits in. Taking off the cover and having a look to ensure the exhaust is free of crud wouldn't hurt as a start. Then check connections, etc..
C1A1364 Pressure Does Not Decrease When Venting Gallery
Exhaust valve stuck closed
Exhaust valve does not
hold minimum retention
pressure
Gallery pipe
blocked/damaged
Pressure sensor fault
Air suspension exhaust
silencer blocked/restricted
pipe blocked/damaged
Reservoir valve block pipes
incorrectly installed
(unions reversed)
C1A3601 Exhaust Valve Exhaust valve, general electrical failure
Exhaust valve
disconnected
Exhaust valve harness
wiring short circuit to
ground or high resistance
Exhaust valve failure
Air suspension control
module failure 2012 SDV6 - it's missing a couple of cylinders
Post #638534 Thu Jan 04 2024 1:25pm
