Home > General > Difference in steering
wiztaz
Hi Guys,
Merry Christmas🎄
I have a 2007 RRS S/C and it drives great. Yesterday I drove a late 2012 RRS SDV6 and steering felt lighter and more responsive compared to my car where the steering feels heavier. Is that normal between the two cars or does my steering need looking at?
Thanks
Post #638442 Sat Dec 30 2023 8:51am
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
normal. have a go in a 494 next & the 2012 will feel heavy.
Post #638462 Sat Dec 30 2023 10:20pm
wiztaz
I just thought the L320’s would all drive the same but guess I am wrong.
Post #638463 Sat Dec 30 2023 11:17pm
There are proably a few variables really like brand and tyre pattern, tyre pressures, has the power steering oil ever been changed etc,etc. could try a bit of wd40 on the steering shaft u/j's but would have thought with u/j's steering would be a bit stiff. Can't really remember if I noticed any difference between my old pre-facelift and facelift L320 cars.
Post #638464 Sat Dec 30 2023 11:30pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
As Col mentioned check the knuckle on your steering linkage from wheel column to the rack.They do seize up and get tight .I make sure mine is well greased up with white grease in my case sprayed it into the Joint.
Post #638467 Sun Dec 31 2023 7:18am
wiztaz
Thank you Col, thank you Iomegas. I will try your suggestions and see how that goes. I was just curious if anyone had noticed a difference in steering between the pre-facelift and facelift or if RR had made any changes to improve the steering in the facelift?
Post #638469 Sun Dec 31 2023 8:29am
