![]() | Home > Maintenance & Modifications > 60 month service for 5.0l SC Autobiogrpahy |
drb5 Member Since: 12 Jul 2023 Location: Scotland Posts: 23 ![]() ![]() |
I see the 5 year service includes a "reservoir - expansion"...whats that then? To replace the actual coolant tank?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
ARC/ACE fluid reservoir |
Thanks for the suggestion…what is it? |
The reservoir for the Dynamic Repsonse/Active Roll Control fluid |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Just out of curiosity DM, but is the D/R filter a integral part of the reservoir now and is the reason the whole reservoir has to be changed?
Correct |
Thanks Mikey. Looking into that now.
Unless they have changed the schedule on the L494, the Supercharger Belt is every 7 years or 105K mls. the AUX belt is every 10 years or 150k mls. however I would suggest replacing the Aux belt when the S/C belt is done as you have to remove it to replace the S/C belt.
Brilliant. Thanks very much Col. |
Ideally should any pulleys be replaced? |
