Home > Maintenance & Modifications > 60 month service for 5.0l SC Autobiogrpahy
drb5
I see the 5 year service includes a "reservoir - expansion"...whats that then? To replace the actual coolant tank?
And would I be as well doing anything else at the same time, that is/are included in future services?
The car is a 2017, but only has 32k miles on it. However, we have no service history on it, other than LR history up to 2018 and 6200 miles. MOT history backs up the low miles mind you.
Post #638366 Wed Dec 27 2023 6:19pm
Disco_Mikey
ARC/ACE fluid reservoir Thumbs Up
Post #638367 Wed Dec 27 2023 6:25pm
drb5
Thanks for the suggestion…what is it? Laughing
Post #638368 Wed Dec 27 2023 7:01pm
Disco_Mikey
The reservoir for the Dynamic Repsonse/Active Roll Control fluid
Post #638370 Wed Dec 27 2023 9:11pm
Just out of curiosity DM, but is the D/R filter a integral part of the reservoir now and is the reason the whole reservoir has to be changed?
Post #638371 Wed Dec 27 2023 10:16pm
Disco_Mikey
Correct Thumbs Up
No serviceable filter inside the valve block anymore, all done via reservoir
Post #638375 Thu Dec 28 2023 10:18am
drb5
Thanks Mikey. Looking into that now.
Should I just consider doing aux belts and changed SC oil?
Post #638387 Thu Dec 28 2023 7:30pm
Unless they have changed the schedule on the L494, the Supercharger Belt is every 7 years or 105K mls. the AUX belt is every 10 years or 150k mls. however I would suggest replacing the Aux belt when the S/C belt is done as you have to remove it to replace the S/C belt.
Post #638391 Thu Dec 28 2023 9:17pm
drb5
Brilliant. Thanks very much Col.
Post #638395 Thu Dec 28 2023 11:00pm
drb5
Ideally should any pulleys be replaced?
Post #638406 Fri Dec 29 2023 10:38am
