Home > Technical > Hard Suspension / variable damping
aln101
Scotland 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
MY 2012
I seem to have the opposite experience to all my searches.
I think the suspension is overly firm.
The handling is certainly impressive for 2.5 tonnes of 4x4, though I would have preferred to avoid all the added complication to achieve this.
My everyday drive is a Transit custom Tourneo and the sport is remarkably similar in road comfort to it.
Potholes and repairs are harsher than I would have expected in the sport, (being used to P38s) and speed bumps are backbreakers.
This I'm guessing is due to overly stiff damping, and of course the low profile tyres to some extent.
Now to the question.
Does anyone know exactly how the variable dampers work? As there are only two tiny wires, I'd assumed they work a solenoid to changeover a high / low damping rate? But that's not really variable, is it?
I'd really like to be able to try whatever is the lowest damping rate, but don't know if this is possible with any of the terrain settings on-road.
Would the dampers default to a low or high rate if I disconnected them, (or one).
rgds Alan Series 3 109
Classic 2-door
101FC GS
Three P38 4.6L
RRS mk1 2012
Post #638219 Wed Dec 20 2023 12:57pm
jimbg
What wheels and tyre size are you running? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #638220 Wed Dec 20 2023 1:06pm
aln101
19in is the smallest I could fit over the later brakes, and they came with 55 profiles (should be 50).
so my 255/55x19 is the most comfortable possible.
Alan Series 3 109
Classic 2-door
101FC GS
Three P38 4.6L
RRS mk1 2012
Post #638225 Wed Dec 20 2023 3:32pm
The RRS's suspension is much firmer than something like a P38 would be. 2012 SDV6 - it's missing a couple of cylinders
Post #638226 Wed Dec 20 2023 4:46pm
aln101
Slight understatement Rolling Eyes
I guessed it would be a bit more road orientated, but I still expected it to "feel" like a Range Rover, and, well, it doesn't really.
More like a heavy go-kart Laughing
Alan Series 3 109
Classic 2-door
101FC GS
Three P38 4.6L
RRS mk1 2012
Post #638227 Wed Dec 20 2023 6:33pm
TheWojtek
The variable dampers, if they break (and they eventually do) will default to the “hard” setting. Actually, just one is enough to give an impression of overly hard suspension.
There is however a known issue with one of the major “OEM-quality” damper manufacturer, who offers the more expensive variable dampers for the L320, which turn out to be just dampers with a resistor pack stuffed inside to fool the chassis into believing it’s a genuine, working thing, so if you’d replace, give a search on the US forum beforehand, it was well pictured there. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #638228 Wed Dec 20 2023 6:49pm
Are your dampers original? How many miles have they covered? 2012 SDV6 - it's missing a couple of cylinders
Post #638232 Wed Dec 20 2023 10:37pm
aln101
Aha, this is the sort of info I was after. Any way of checking that would be obvious.
RRSTDV8 - Vehicle is only at 70,000 so original dampers I would have thought.
Alan Series 3 109
Classic 2-door
101FC GS
Three P38 4.6L
RRS mk1 2012
Post #638234 Thu Dec 21 2023 1:30am
Have you actually had the vehicle read for fault code's, or have any warning lights showing, as the system consists of slightly more than a couple of wires going to a solenoid in the damper, there is over a hundred codes attributed to the ADM module so it might help. I had my old P38 for over ten years prior to having both a pre-facelift and facelift variants of the Sport although only facelift one has CVD obviously, there is no comparison in ride level, I would describe the P38 ride and handling more to wallowing around in a old boat. Have you driven any other Sport's with the system to make a comparison?
Post #638235 Thu Dec 21 2023 2:46am
Pistnbroke
When the dampers go soft a pothole will throw you into the next lane so be careful.
What tyre pressure are you using that makes a big difference. Thats your primary shock absorber.
I find 36 in the back is far too much Always listen to old people or when they die you will live on in ignorance.
Post #638240 Thu Dec 21 2023 9:32am
I run mine at 36f / 39r and don't have issues. So if one finds the car struggling with potholes then that might suggest an issue with bushes or dampers. 2012 SDV6 - it's missing a couple of cylinders
Post #638241 Thu Dec 21 2023 10:05am
Alan
Could be the good old lower arm bushes at the front. 70k miles is around the time they often need looking at. I know mine felt very different after having the lower arms replaced a few years ago. Much more "magic carpet" as one might expect for the brand. 2012 SDV6 - it's missing a couple of cylinders
Post #638242 Thu Dec 21 2023 10:06am
Pistnbroke
I have new rear shocks and front sus arms and run at 32 psi all round Always listen to old people or when they die you will live on in ignorance.
Post #638243 Thu Dec 21 2023 10:31am
32psi all round? Yikes, that's very low for the rears. What tyre / sizes are you running? 2012 SDV6 - it's missing a couple of cylinders
Post #638245 Thu Dec 21 2023 11:11am
Pistnbroke
255 55 19 Always listen to old people or when they die you will live on in ignorance.
Post #638246 Thu Dec 21 2023 11:14am
