![]() | Home > Technical > Hard Suspension / variable damping |
aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 49 ![]() ![]() ![]() |
Forgot to mention-
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
I tend to run 33 Front and 36 Rear for normal load and find it works fine for me personally, taking into account the pressure will go up slightly when tyres warmed up anyway.
Ok then. Tyres about as good as we can get, so back to the dampers |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
If you were expecting Range Rover ride, you've come to the wrong place. The L320 RRS isn't a Range Rover other than in its badges. It's a Discovery with suspension tuned to be more capable across a fast road. Ergo, it has firmer damping.
