Home > Maintenance & Modifications > Tow-hitch problem - replacing key barrel |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 142 |
You need to knock out the roll pin passing through the handle, it will then pull away with the barrel as one unit.
Fri Dec 15 2023 1:24pm |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 317 |
Many thanks.......that did help.....job done. Andrew Andrew Kennedy |
Fri Dec 15 2023 2:14pm |
