Home > Technical > Help on suspension calibration gap tool |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
contact PAT @GAP.
Sun Dec 10 2023 11:26am |
Ray1979 Member Since: 10 Dec 2023 Location: Rochester Posts: 13 |
Thank u I have emailed Patrick so hopefully hear something back in next couple of days I'm just really stumped as everything is new and works as such though live data the cars just seems to have lost the ability to level and files |
Sun Dec 10 2023 11:33am |
Pat at gap is at a loss
Wed Dec 13 2023 2:46pm |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 37 |
Have you probed the wiring back to the ECU from the connectors on the height sensors. I just did some work on my control arms and had to replace 3 of the 4 connectors and a section of corroded wire on one connector. 2009 Range Rover Sport Supercharged |
Wed Dec 13 2023 3:03pm |
Yep belled them from ecu to plug.
Wed Dec 13 2023 3:08pm |
https://www.rrsport.co.uk/gallery/albums/u...C1699.tiff
Wed Dec 13 2023 3:30pm |
cheers for that ill double check tomorrow and ill also try run wires direct to ecu from plug and see if that helps.i cant think of anything else to try gap said if its not the wire there at a lose as the module doesnt contain a readable ccf so they cant even rewrite that for me its a set module and u just work off the main.i cant find anything bent,out of place etc,everuone whos tried have come up with a blank so far so wires r the last resort but they all bell accross so i cant see it being them |
Wed Dec 13 2023 3:57pm |
bit puzzled as the plugs ive seen show 1 as orange yellow 4 orange red..5 orange black wiring on that link shows different i believe |
Wed Dec 13 2023 4:11pm |
Is this for a 2009 model plz l320 |
Wed Dec 13 2023 7:22pm |
Mine had pin
Thu Dec 14 2023 11:35am |
See below for wiring specific to your vehicle to confirm the colours.
Thu Dec 14 2023 1:30pm |
