![]() | Home > Technical > Help on suspension calibration gap tool |
contact PAT @GAP.
Ray1979 Member Since: 10 Dec 2023 Location: Rochester Posts: 13 ![]() ![]() ![]() |
Thank u I have emailed Patrick so hopefully hear something back in next couple of days I'm just really stumped as everything is new and works as such though live data the cars just seems to have lost the ability to level and files |
Pat at gap is at a loss
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 41 ![]() ![]() ![]() |
Have you probed the wiring back to the ECU from the connectors on the height sensors. I just did some work on my control arms and had to replace 3 of the 4 connectors and a section of corroded wire on one connector. 2009 Range Rover Sport Supercharged |
Yep belled them from ecu to plug.
https://www.rrsport.co.uk/gallery/albums/u...C1699.tiff
cheers for that ill double check tomorrow and ill also try run wires direct to ecu from plug and see if that helps.i cant think of anything else to try gap said if its not the wire there at a lose as the module doesnt contain a readable ccf so they cant even rewrite that for me its a set module and u just work off the main.i cant find anything bent,out of place etc,everuone whos tried have come up with a blank so far so wires r the last resort but they all bell accross so i cant see it being them |
bit puzzled as the plugs ive seen show 1 as orange yellow 4 orange red..5 orange black wiring on that link shows different i believe |
Is this for a 2009 model plz l320 |
Mine had pin
See below for wiring specific to your vehicle to confirm the colours.
