Home > General (L494) > Overfinch 5.0 SC V8 exhaust too loud |
drb5 Member Since: 12 Jul 2023 Location: Scotland Posts: 20 |
I’m actually awaiting their reply to another question I have, so will put it to them when I hear from them. Thanks Tim. |
Sun Dec 10 2023 4:40pm |
ok, so on further investigating, the system is completely standard apart from the downpipes having been removed and the shady welding which was done for some unknown reason. The 2 centre boxes and 2 backbones have not been touched. All welding is to OE spec.
Wed Dec 13 2023 10:22am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Yes, they flow a lot more. OEM cats are between 400 to 700 cells (the higher the EU-norm, the more cells, obviously) which block between 35 and 50% of the cat diameter. Sport cats are mostly 200 cells which block 15 to 25% of the diameter. Since the cat is wider than the adjacent elements of the exhaust system, it pronounces the bass rumble created by the sudden expansion of the exhaust gases in the increased volume. Additionally, this increased volume allows for the pulses to overlap, creating even more noise. Regards etc.,
Wed Dec 13 2023 12:36pm |
I've got you, thanks for explaining.
Wed Dec 13 2023 1:22pm |
I don't have the specs of the stock cats available so can not really compare yet endorse any particular product. I believe if the cell number checks out, they'd be good to go. I would check, however, if your RR had a remap to suit the high-flow cats, as it would be not compatible with the stock...ish units. Regards etc.,
Wed Dec 13 2023 4:23pm |
Yes, that would certainly be an issue. I’ve considered the idea of requiring a remap after fitting different cat’s. It could come down to doing this, or my wife may refuse to drive it. lol
Wed Dec 13 2023 4:41pm |
