![]() | Home > General (L494) > Overfinch 5.0 SC V8 exhaust too loud |
drb5 Member Since: 12 Jul 2023 Location: Scotland Posts: 23 ![]() ![]() |
Hello all.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Downpipes will not do any difference, it's not a turbo.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4442 ![]() ![]() ![]() |
What model do you have? |
That makes sense. Just seen a video where an Overfinch had a loud exhaust and the chap fixing it mentioned OF removing downpipes and backbox baffles so maybe it’s a fairly easy rectified. 🤔 It’s a 2017. |
Replacing downpipes (which would essentially create a whole new exhaust from the headers back) with high-flow units does not have a big implication soundwise, has some challenges though:
Thank you very much for the information Wojtek. |
Thanks Dave. Hope to confirm later today. |
Dave has a point. From what I've found, the Overfinch exhaust replaces the stock middle resonator with a significantly smaller unit and uses homeopathic amounts of muffling in rear silencers in the L320 and I wouldn't expect the L494 unit to be very different. @drb5 - once you're from below the car, check if yours is similar. Regards etc.,
Well, it isn’t quite how I imagined it to be.
Oh God, that is painful.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
Not sure about Overfinch being responsible for that, looks more like the welding was done by The Backstreet Bodgit Company.
I’d have agreed with you Col, but from what I’ve managed to find out so far, it looks like OF dont this type of job up to maybe 2017/2018 and then they brought out their own system…? |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
Why not speak to Over Finch and ask for their advice? Tim
