![]() | Home > Technical > Removing compressor - tips on getting air lines out |
I had a similar problem.
ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 32 ![]() ![]() ![]() |
Thanks - exactly what i'm doing - toothbrushes around the collet; WD40 in there; try again.....sore arms/fingers... |
I also had the exact same issue,, rather than spend hours struggling I cut the pipe on the vertical section and used a straight pushfit connector,, 8mm I believe. 2010 RRS, TDV8
Thanks - think i may have to go for that option too.
Bit confused as to what your referring to as the intake silencer??,,, a silencer would only be on the exhaust. Do you have a pic of the bit you are referring to. Remove the whole compressor and work on it on a bench,,, inlet and exhaust pipes off and a few bolts,,,, makes for an easy life. 2010 RRS, TDV8
You could think of it as an air filter |
@gogsy1956 see below pic (4) for the bit i'm referring to:
Just to update on the tweaks i made to the bracket....in the end, didn't bother putting it on studs as the new spire nuts work well and having slotted the top bolt, can get the whole thing in and out in a few minutes now.
