![]() | Home > General (L494) > Multiple faults ???? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
I'd check the ABS sensor and wiring on the corner that was worked on. Damage will give you those faults as the system won't know what that wheel is doing. 2012 SDV6 - it's missing a couple of cylinders
Sgill1982 Member Since: 07 Jul 2023 Location: Kent Posts: 5 ![]() ![]() |
I have taken the wheel off that was referbished. Disconnected the multi plug and reattached, checked cables all ok.
Brian181 Member Since: 10 Dec 2024 Location: Aberdeen Posts: 4 ![]() ![]() ![]() |
Hi, have you managed to resolve this problem?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4450 ![]() ![]() ![]() |
Thanks, I have checked them both and both have good connections, no corrosion.
Fault codes are your next step |
Hiya, codes are:-
