Home > General (L494) > Multiple faults ????
Sgill1982
I recently had my rear n/s wheel removed for referb.
When it was replaced I drove the car and it had multiple faults on the dash.
ABS fault
Collision avoidance fault
Traction control
Stability
Loss of power steering.
I’m presuming it’s a ground fault.
I’ve checked the cable behind the front wheel arch trim and they seem ok.
Does anyone have any other ideas?
2019 autobiography dynamic 3.0d
Post #637941 Sat Dec 09 2023 11:43am
I'd check the ABS sensor and wiring on the corner that was worked on. Damage will give you those faults as the system won't know what that wheel is doing. 2012 SDV6 - it's missing a couple of cylinders
Post #637946 Sat Dec 09 2023 3:00pm
Sgill1982
I have taken the wheel off that was referbished. Disconnected the multi plug and reattached, checked cables all ok.
I thought I’d try the from o/s again as this keeps coming up as a solution on other forums. Disconnected the earth cleaned and reattached. Still the same. Pic attached.
I have also disconnected the earth on the battery and reattached, checked all the earths around the battery.
Checked the big earth under the car, central.
There must be one which is corroded or loose somewhere???
Post #637951 Sat Dec 09 2023 4:10pm
Sgill1982
Earth in wheel arch
Post #637952 Sat Dec 09 2023 4:11pm
Brian181
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Hi, have you managed to resolve this problem?
I have one that sounds identical.
I have replaced osr abs sensor, new battery & checked earth points both front wheel arches and around the boot, but still have the faults and no power steering.
Appreciate your feedback
Regards
Brian
Post #645700 Tue Dec 10 2024 9:29pm
Disco_Mikey
Earth point in each front wheel arch. Start with them Thumbs Up
Post #645701 Tue Dec 10 2024 9:36pm
Brian181
Thanks, I have checked them both and both have good connections, no corrosion.
Post #645705 Wed Dec 11 2024 10:16am
Disco_Mikey
Fault codes are your next step Thumbs Up
Post #645707 Wed Dec 11 2024 12:33pm
Brian181
Hiya, codes are:-
U0001-81
B1484-15
B13C2-49
U0447-29
05ED-16
4515-31
U0418-68
U3003-16
Thanks
Post #645708 Wed Dec 11 2024 12:54pm
