![]() | Home > General (L494) > How to fix the Access height intermittent fault? |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
I thought all L494's had the auto lowering option in the menus? 2023 P440e SE Dynamic on order -cancelled
jamesgarbett Member Since: 12 Jan 2021 Location: Mellor Posts: 34 ![]() ![]() |
Unsure - but mine - MY14 doesnt |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
It’s only available on MY16 I think. |
On the L320 RRS, this error was usually caused by the air suspension exhaust valve sticking. 2012 SDV6 - it's missing a couple of cylinders
OK thanks any idea if that applies on L494? or how to fix it? |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 85 ![]() ![]() |
If it attempts to go into access, drops then raises to max height then there is an issue with the standard height in that the car is sitting too low and when you select access the car drops too much and then goes to default which is to extend to protect the car.
Sam_RRS Member Since: 12 Oct 2023 Location: Newcastle Posts: 4 ![]() ![]() ![]() |
I would check the exhaust valve on the compressor under the spare wheel. Simply undo cover (metal clips all way around) for access. Mine did this when I first bought it. It'll have what looks like white mould on it. Simple fix & cheap for once. Too many horror stories making people worry about nothing. Hope this helps |
thanks - can it be cleaned or does it need a new one? |
Don't think so they're only like £15 online, suspension compressor silencer it just looks like a gold sparkly bolt really. Obviously could be a different fault but worth try mate |
Mac35 Member Since: 15 Dec 2023 Location: Angus Posts: 48 ![]() ![]() |
Little bit late maybe but they can be cleaned. I had a similar issue with mine. Wouldn’t go into access mode it would start going down then go into extended mode. Took the silencer off and cleaned it in isopropyl alcohol and it goes into access mode no problem now. |
Thanks
