Home > General (L494) > How to fix the Access height intermittent fault?
jamesgarbett
Every few days when i try to select access height the car goes to extended height mode.
This usually clears after 3-4 attempts
It's a 1st world problem but is there an easy fix?
My car doesnt have auto height adjustment i have to select it from near the gearshift
Post #637342 Thu Nov 16 2023 4:14pm
jimbg
I thought all L494's had the auto lowering option in the menus? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #637344 Thu Nov 16 2023 4:18pm
jamesgarbett
Unsure - but mine - MY14 doesnt
Post #637345 Thu Nov 16 2023 4:20pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
It’s only available on MY16 I think.
Post #637347 Thu Nov 16 2023 5:24pm
On the L320 RRS, this error was usually caused by the air suspension exhaust valve sticking. 2012 SDV6 - it's missing a couple of cylinders
Post #637349 Thu Nov 16 2023 6:00pm
jamesgarbett
OK thanks any idea if that applies on L494? or how to fix it?
Post #637371 Fri Nov 17 2023 11:53am
Nick900
If it attempts to go into access, drops then raises to max height then there is an issue with the standard height in that the car is sitting too low and when you select access the car drops too much and then goes to default which is to extend to protect the car.
You could try and adaptation but ideally you need GAP IID to do this. Some other diagnostic computers might be able to do this too but GAP allows you to see the measurements and make adjustments etc.
Post #637396 Sat Nov 18 2023 10:42am
Sam_RRS
England 2013 Range Rover Sport SDV6 HSE Fuji White
I would check the exhaust valve on the compressor under the spare wheel. Simply undo cover (metal clips all way around) for access. Mine did this when I first bought it. It'll have what looks like white mould on it. Simple fix & cheap for once. Too many horror stories making people worry about nothing. Hope this helps
Post #637556 Thu Nov 23 2023 9:51pm
jamesgarbett
thanks - can it be cleaned or does it need a new one?
Post #637560 Thu Nov 23 2023 10:51pm
Sam_RRS
Don't think so they're only like £15 online, suspension compressor silencer it just looks like a gold sparkly bolt really. Obviously could be a different fault but worth try mate
Post #637582 Fri Nov 24 2023 8:28pm
Mac35
Scotland
Little bit late maybe but they can be cleaned. I had a similar issue with mine. Wouldn’t go into access mode it would start going down then go into extended mode. Took the silencer off and cleaned it in isopropyl alcohol and it goes into access mode no problem now.
Post #638353 Tue Dec 26 2023 5:42pm
jamesgarbett
Thanks
I fitted a new one in the end but the problem persists so just going to live with it
Post #638362 Wed Dec 27 2023 8:03am
