Home > Maintenance & Modifications > Pitch of threads for rear tie rod bolts
Nicjan
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I'm trying to find the pitch of the thread for the rear tie rod bolt.
The bolt is named as the rear tie link bush bolt .
I know it's a M14 x80mm bolt but unsure if it's 2mm or 1.5mm pitch.
I need to order the correct size helicoil kit to repair the hub.
Any help appreciated.
Post #637196 Sat Nov 11 2023 9:36am
Buy a thread gauge tool from screwfix, 3 quid for a cheap plastic one and check the bolt.
Post #637197 Sat Nov 11 2023 10:55am
Nicjan
Thanks Col
I thought someone on here might now to save time
Post #637198 Sat Nov 11 2023 11:21am
Count the threads on the bolt then, the tpi on the course will be 12/13, fine wil be 16/17, just divde 25.4 x1.5 for fine or 25.4 x 2.00 for course.
Post #637199 Sat Nov 11 2023 11:45am
Nicjan
Thanks Col
That's great information cheers
Post #637200 Sat Nov 11 2023 11:47am
