Home > Faults & Fixes > Heated wing mirrors, rear screen and steering wheel failure
AcePratt
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Hi Folks,
Now the cold weather has arrived, I have noticed that the heated wing mirrors, rear screen and steering wheel are not working. The front heated screen is fine. Does anyone have any advise as to where to look to rectify these faults?
I'm thinking it could be a fuse, but obviously I'm not to sure...
Thank you.
Post #636959 Mon Oct 30 2023 12:57pm
Not sure it would be a fuse as it would have to be at least 3 blown if not four, but is always possible I guess, the rear screen and heated steering wheel are fused separately, I believe the heated mirrors are controlled by the door modules which are again on different fuse's, but if they were blown I would think a few other things in the door would not work either. Not sure the are in the same location for the 2010 cars but on the 12/13, vehicles rear screen heater is fuse No.15 steering wheel is No. 20, the door modules are I think No's. 30 and 32 all in the passenger foot well compartment behind the glove box.
Post #636973 Tue Oct 31 2023 9:01am
AcePratt
Thanks Col, it turns out my rear heated screen and rear view mirror are working, just very slow to heat-up, leaving just the heated wheel to sort. I have checked the fuse and it's all good, so I will dig a little deeper when I get a chance.
Post #637998 Mon Dec 11 2023 1:11pm
What state is the battery in? And the alternator? The car's power system actively reduces/stops the power available to various heated elements if the load is more than the battery and alternator can provide. 2012 SDV6 - it's missing a couple of cylinders
Post #637999 Mon Dec 11 2023 2:31pm
AcePratt
Thanks for the advice, I will charge the battery overnight to see if this helps.
Post #638000 Mon Dec 11 2023 3:13pm
