![]() | Home > Faults & Fixes > Heated wing mirrors, rear screen and steering wheel failure |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Not sure it would be a fuse as it would have to be at least 3 blown if not four, but is always possible I guess, the rear screen and heated steering wheel are fused separately, I believe the heated mirrors are controlled by the door modules which are again on different fuse's, but if they were blown I would think a few other things in the door would not work either. Not sure the are in the same location for the 2010 cars but on the 12/13, vehicles rear screen heater is fuse No.15 steering wheel is No. 20, the door modules are I think No's. 30 and 32 all in the passenger foot well compartment behind the glove box.
AcePratt Member Since: 23 Oct 2023 Location: Leicester Posts: 16 ![]() ![]() ![]() |
Thanks Col, it turns out my rear heated screen and rear view mirror are working, just very slow to heat-up, leaving just the heated wheel to sort. I have checked the fuse and it's all good, so I will dig a little deeper when I get a chance. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
What state is the battery in? And the alternator? The car's power system actively reduces/stops the power available to various heated elements if the load is more than the battery and alternator can provide. 2012 SDV6 - it's missing a couple of cylinders
Thanks for the advice, I will charge the battery overnight to see if this helps. |
