Home > General > Keys L320 Model year 2005
skullbyka
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
Can anyone tell me if the battery in the key fob on the RRS 2005 is charged when in use or exactly how it charges ?
Thanks I am the darkness before the storm
Post #636877 Fri Oct 27 2023 6:02pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
It’s a while since I had one but I don’t think the battery in the key fob charged at all. Just needs replacement from time to time.
Post #636883 Fri Oct 27 2023 9:51pm
The original key charges when it is in the ignition barrel. Which is why it's useful to use the spare key now and then to make sure it's battery is ok. 2012 SDV6 - it's missing a couple of cylinders
Post #636884 Fri Oct 27 2023 11:03pm
Stevepd
As above 100%. Try and rotate your keys rather than using one set and like all batteries there will come a time when it needs replaced. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #636888 Sat Oct 28 2023 4:42am
skullbyka
Thanks to all that responded . I think the general consensus was correct as after using the apparently "dying" key several times it appears to have charged itself up and I have had no further trouble from it.
Thanks Guys. I am the darkness before the storm
Post #637148 Wed Nov 08 2023 2:19pm
One thing to note about the original keys is that each one has its own associated memory settings. So if you use both (as you should to keep the batteries happy) then you may need to set up the seat/mirrors for each key if you have more than one driver.
The later keys don't do this - there's one set of memories and they apply to both keys. 2012 SDV6 - it's missing a couple of cylinders
Post #637150 Wed Nov 08 2023 3:38pm
skullbyka
Thanks to everyone for the invaluable answers 7 information
Just wanted to say thank you to all who tooke the time to offer suggestions and share information here. I am the darkness before the storm
Post #644005 Mon Sep 02 2024 9:17am
