Home > Technical > Removing air suspension unit. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
If you're just taking the air compressor off, you don't need to depressurise the system - the reservoir valve block immediately adjacent to the compressor separates the compressor from the rest of the system. You only need to depressurise if working on anything else downstream of that valve block i.e. everything else.
Thu Oct 19 2023 4:07pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 415 |
No not the compressor the air bag /shock suspension unit. Always listen to old people or when they die you will live on in ignorance.
Thu Oct 19 2023 4:09pm |
I seem to remember that people have just loosened the voss connector a touch and let it depressurise that way. I'm sure a search here, and more importantly, on Disco3.com will confirm that. 2012 SDV6 - it's missing a couple of cylinders
Thu Oct 19 2023 8:46pm |
Thats what I was thinking but wanted to confirm,
Fri Oct 20 2023 7:39am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Just crack the connectors (front-rear/centre valve blocks) until you hear a slight hiss then go and have a cup of tea and when you finish the system will be decompressed. 07MY RRS TDV6
Fri Oct 20 2023 10:20am |
