Home > Technical > Removing air suspension unit.
Pistnbroke
May need to remove the air suspension unit..quite happy with the mechanical side but what is the best way to release the air from the system before unbolting Always listen to old people or when they die you will live on in ignorance.
Post #636700 Thu Oct 19 2023 4:03pm
If you're just taking the air compressor off, you don't need to depressurise the system - the reservoir valve block immediately adjacent to the compressor separates the compressor from the rest of the system. You only need to depressurise if working on anything else downstream of that valve block i.e. everything else.
You can download the workshop manual from here: https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #636704 Thu Oct 19 2023 5:07pm
Pistnbroke
No not the compressor the air bag /shock suspension unit. Always listen to old people or when they die you will live on in ignorance.
Post #636705 Thu Oct 19 2023 5:09pm
I seem to remember that people have just loosened the voss connector a touch and let it depressurise that way. I'm sure a search here, and more importantly, on Disco3.com will confirm that. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #636710 Thu Oct 19 2023 9:46pm
Pistnbroke
Thats what I was thinking but wanted to confirm,
Many Thanks Always listen to old people or when they die you will live on in ignorance.
Post #636712 Fri Oct 20 2023 8:39am
garrycol
Australia
Just crack the connectors (front-rear/centre valve blocks) until you hear a slight hiss then go and have a cup of tea and when you finish the system will be decompressed. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #636719 Fri Oct 20 2023 11:20am
