![]() | Home > General > Wet Boot |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Might be some use, might not, could be worth checking the drain tube to the rear in No.3 of the illustration, might be blocked or perished in someway, but not really sure if they only apply if sunroof fitted.
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167 ![]() ![]() ![]() |
Eh up
Ehup all
Basically just pushed/pressed on, from the factory there is a small amount of white adhesive used, but it is not on replacement seals, there is enough of the adhesive left behind when removing old seal for the new one although not really needed, try and keep the adhesive off your fingers as it's the sort of stuff that no matter how hard you try it seems to get every where.
Eh up all
