Home > Faults & Fixes > Yet another Suspension fault |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 142 |
I think the problem is more connected with the Ace system as opposed to the air suspension, its been a long time since I has a L320, but seem to recall when I had that warning it was Ace related. |
Thu Oct 12 2023 5:47pm |
Hullrrs Member Since: 29 Aug 2023 Location: Hull Yorkshire Posts: 33 |
Thanks for the fast reply
Thu Oct 12 2023 6:00pm |
I definitely had this once driving back from France, yellow warning, vehicle leans when cornering and normal height only as is yours. Went into the MD as was under warranty at the time, just can't remember what their fix was!!
Thu Oct 12 2023 6:19pm |
Hi
Thu Oct 12 2023 7:17pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 344 |
Check the air tank at the front they rust out use a spray and soapy water iv had slow to raise on both mine it was the air tank both times gallery pressure was fine as well. |
Fri Oct 13 2023 7:42am |
I will check this tomorrow when it’s dry. Strange thing is it raises and drops really fast and doesn’t lower when left unused.
Fri Oct 13 2023 6:46pm |
Exactly same as mine, the air tank is proberly 1 of the easiest repairs iv done on our cars and iv done a fair few |
Fri Oct 13 2023 7:35pm |
Right so quick update
Sat Oct 14 2023 5:19pm |
Good progress! they are common for splitting across the top as they are plastic. Pretty sure you can get a billet alloy one, at least certainly for the AMK compressor. |
Sat Oct 14 2023 5:23pm |
That's a standard hitachi compressor and the normal place where they leak.
Sat Oct 14 2023 5:36pm |
Excellent thank you I’m ordering one now £40 delivered. From the bay an alloy one with the new filters and medium
Sat Oct 14 2023 5:47pm |
Yes you would need to remove the pump to replace the dryer medium and that's a whole lot of extra trouble. Usually the pump mounting bolts are seized and the chassis fixings are rusted out that's another ebay kit.
Sat Oct 14 2023 6:11pm |
Well fingers crossed I will change just the cap and see what happens.
Sat Oct 14 2023 6:25pm |
Update
Wed Oct 18 2023 4:19pm |
