Home > Technical > Remove pedestal sides?
Bit extreme but have you searched any breakers yard for a write off or scrap one where the floor is ok, and you could cut out the section you need, not sure if there are any differences in the floor pan on say a 2012/13 though as there have been a lot of changes to the part number over the years for the bodyshell. Funnily enough the part number for the floor section that is available is the same as the Disco 4, but it is still the only section available for the Disco, but it might wider your option if you did look for a breaker. Another option could be a good metal fabricating or custom car building body shop could fabricate a section for you, but I can't imagine it would cheap.
Post #636481 Sun Oct 08 2023 12:23am
It’s not structural. (Assuming not within an inch or seat mounts )
So I would fix the water leak. Then put some rust treatment or oil over the area
Post #636484 Sun Oct 08 2023 9:19am
Might have different regulations in Sweden.
Post #636485 Sun Oct 08 2023 9:52am
pelle
Sweden
Thank you.
I Will check if it is possible to save the floor.
It is not interfering with seat installation.
There are not so many RRS or D3/4 with breakers in Sweden, but I will check.
I will be back.
Post #636486 Sun Oct 08 2023 2:36pm
pelle
Sweden
Is this floor inside the body shell?
I meaning, is there an outside/another floor below?
It must be or…?
Post #636487 Sun Oct 08 2023 3:48pm
I think you will find the only double skinned part will be the inner sill at the side.
Post #636494 Sun Oct 08 2023 11:13pm
pelle
Sweden
You are Right Col. Only the floor and not anything below.
My floor is too bad to keep so it must be repaired/changed.
Luckily I have found a D3 ready for scrap-yard ( I don’t know the correct word) and hope that
I can find a useful floor there.
I will check it tomorrow.
A little bit of light in the tunnel 😉.
I don’t know yet where the water comes from?.
Aircon drains cleaning is next job?
Any other ideas?
//pelle
Post #636636 Tue Oct 17 2023 12:01am
There are several areas where leaks can occur, if you do a search quite a few posts should turn up, I believe the main ones are the trim clips for the 'A' post outer trims on the earlier cars at least, sunroof drain tubes if you have a sunroof, can also leak in through the vent opening under the front screen scuttle panel, sure there are other areas which other members can enlighten you on.
Post #636637 Tue Oct 17 2023 4:44am
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi Col,
Surprisingly, my facelift 2010 RRS, the A posts were the same as the prefacelift models. I had to seal the holes under the trim too.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #636641 Tue Oct 17 2023 6:23am
pelle
Sweden
Thanks for help with the possible source of water ingress.
I have fixed the drain from sunroof forward left and right side and it is working.
Aircon drain looks ok inside but have to find the ends underside.
If there is a leak at the air intake below the front window I think the water would wet/pass
the pollen filter? Dry pollen filter, no leak?
I will start pouring water in the A-pillar holes under the trims and check inside.
I have found a good floor today and cut it out in the weekend. 😎
Post #636668 Tue Oct 17 2023 11:56pm
pelle
Sweden
Do know how to disconnect the black ventilation (very flat) tubes under the mat from the center console?
Seen in picture above.
Post #636669 Wed Oct 18 2023 12:26am
pelle
Sweden
No problem when using som muscles 💪.
Post #636818 Tue Oct 24 2023 11:56pm
