Home > Technical > Remove pedestal sides?
pelle
Sweden
How do I remove the side of the central pedestal? RRS S/C 2005
I don’t find that in my workshop manual.
I need to remove the “carpet?” to check my rusty floor.
//Pelle
Post #636006 Wed Sep 20 2023 4:11pm
The whole center console ?
It's not easy.
remove radio surround. Pull grey/wood trim from the bottom
I think you need to remove radio and then remove climate panel
Pull the wood or grey trims outward. Remove screws at the front
Pull the gear knob off by pulling it off, upwards
Then the center top can be lifted. Unplug lots of plugs
Remove the fridge or box
I think you need to remove the gear selector block. 4 bolts.
There is then a base under the gear selector which needs removing. 4 bolts.
Then the center console screws/botls can be removed.
Something like that anyway
Post #636007 Wed Sep 20 2023 4:25pm
pelle
Sweden
I hope I only need to remove one side if possible.
I have removed the top of the pedestal with all the el. connections.
Post #636009 Wed Sep 20 2023 4:31pm
maybe post a photo of what you want to remove ?
Post #636011 Wed Sep 20 2023 4:34pm
pelle
Sweden
I think it my be turned sideway, sorry.
The side panel holds the floor mat /carpet in place and I think I have to remove
it to get the carpet out.
//Pelle
Post #636013 Wed Sep 20 2023 4:55pm
pelle
Sweden
I don´t know if there is information in the Workshop manual about this i chapter 5.
I don't know if I missing some parts in chapter 5.
Post #636015 Wed Sep 20 2023 5:05pm
pelle
Sweden
@ Andy K, thank you for your answer.
I have problems to find how to remove the fridge if that is needed.
Post #636016 Wed Sep 20 2023 5:09pm
The front carpet is in one piece covering the full width of the floor to remove it completely you will need to remove the complete center console, I don't think you can just remove the console side panels in situ. you have to remove the whole console.
You need section 501-12 of chapter 5 in the workshop manual, unfortunately for whatever reason chapter 5 does not appear to be included in all versions of the manual for 2005/2009 cars.
Post #636028 Wed Sep 20 2023 9:04pm
pelle
Sweden
Thank you very much Col.
I have to find that chapter.
Ok, I understand that this will be more stripping than I hoped for.
Thanks for your help.
I have googled to find a new floor (if mine is too bad) but can not find anything.
Front seat left side new floor, can you give me help to find the that part?
RRS MY 2005. If there is a part number you know it can help.
//Pelle
Post #636029 Wed Sep 20 2023 9:45pm
I have looked at a old parts list and it does not appear to list the front floor pan separate, it is an integral part of the bodyshell, there is one listed AFD780011 but it is showing for the rear.
Post #636030 Wed Sep 20 2023 10:09pm
pelle
Sweden
Thaks Col.
Ok. I have to remove the Console and check the floor and find the source of leaking water.
There is a connector behind the transmission selector lever box, I don’t know how to remove it.
Why is my photos shown sideways?
Post #636338 Tue Oct 03 2023 10:53pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
If you want to check then you could do what I did in my Jag ...cut a nice flap (3 sides ) in the centre and when you finished glue it back and put your cover mat on it.
If its that rusty can you not probe it from under the car . Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #636340 Wed Oct 04 2023 6:31am
I don’t recall it being a difficult connector to remove.
Most will have a tab that needs pushing.
Some will retract by moving at a right angle. Maybe Martin knows.
The 2 AC drains are a little forward from where you are. I think, either side of console
Post #636356 Wed Oct 04 2023 9:39am
pelle
Sweden
Thank you Andy K. I found out that it is a lever to open up the lock 👍
I have finally removed the console and can lift the carpet higher up.
The floor is very badly rusted.
This picture is also 90 degrees sideways 🤨
Post #636397 Thu Oct 05 2023 4:22pm
pelle
Sweden
OK. Thanks everybody for guiding me forward.
I do not know what to do next.
Have anybody you know of had same problem with rust, and fixet it?
No spareparts available as Col informed me.
Have Disco 3/4 the same floor and problem?
maybe I should start i new post in a forum about my problem with rust in the front floor.?
Pelle
Post #636480 Sat Oct 07 2023 10:58pm
