Home > Technical > Adding new key
Johnart88
United Kingdom 2010 Range Rover Sport 4.4 V8 Autobiography Bali Blue
Adding new key
Hey everyone, been viewing this forum for 6 months and in that 6 months gone from a novice with range rovers, to less of a novice everything pretty much that could go wrong from the sunroof leaking to the ACE pipes bursting, but ive persisted and done the research im hoping to post some of my solutions which hasn't resulted in thousands being spent, any way enough of that rant,
I have an issue adding a key with the Gapiid tool, I changed a battery cr2032 in one and now its gone blank and unresponsive and my main key is saying low battery, when I try to do it with the gapiid tool it says error, ive noticed the range has 4 stored keys already is that the maximum ?
thanks everyone
Post #636400 Thu Oct 05 2023 6:13pm
Mafya
United Kingdom 2010 Range Rover Sport TDV8 HSE Lux Buckingham Blue
I’ve done a new key for my Range Rover Evoque using the Gap iid tool but I had to record my ecu infos and send it in to gap and then was told to download something via the Gap updater and then went on to cut 2 keys making a toatal of 5 keys on the car system.
You may have to contact Gap support…
Post #636446 Sat Oct 07 2023 4:08am
