![]() | Home > General > New owner sadly with an issue already!-TDV8 engine system |
Might be worth checking for a split intercooler hose, not uncommon I believe.
TGJ Member Since: 04 Oct 2023 Location: Hants Posts: 13 ![]() ![]() ![]() |
Thought the best thing to do would be to get it plugged in at a Land Rover place and got these fault codes:
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Yes, the sound change happens when the vanes on one of (or rarely: both) the turbochargers are wide open. This happens when the actuator action is outside the design envelope and the ECU decides to go limp mode - including cutting the boost to 0 - to prevent damage. Been there, done that.
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 254 ![]() |
Hi same thing happend me to, see my earlier post this week.
That’s really informative, thanks a lot ![]() I’ve checked the boost pipes and no splits so can rule that out, would the noise change indicate that it is more likely sticky vanes/actuators than the inlet for example?. Hope it’s not turbo vanes as it had 2 new turbos 3 years and 30k miles ago looking at the receipts. Part of the reason this one appealed l, I will try some turbo cleaner and a heavier foot!. The guy who plugged it in did rev it with the diagnostic software running and said the actuators were working but it was already in limp mode when plugged in so maybe they weren’t working as well as thought. Do you think it’s worth trying to free them up more manually still?. |
I am quite sure moving them by hand will not do any harm.
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Cracked manifold ? |
Thanks again, I’m going to try and free up the actuators tomorrow and see if that helps, I’ve ordered some turbo cleaner, both the additive to the diesel tank and the one you spray down the intake and got it booked in somewhere in a couple of weeks, if it started to do it once every 3 months I’d just live with it but pretty much every trip I can’t!, if it is an inlet then it will have to be done, very much doubt and hope it’s not a turbo seeing as they’ve already been done!. |
Thought of that, doesn’t explain a V8 rumble that disappears on engine restart. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Who did you use in Hampshire as a matter of interest? Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Right I’m about to start trying to free up the actuators as first port of call, do the front wheels need to be off to access them from underneath?. |
It's easier. See:
Well that’s a bust unfortunately, my 4x4 trolley jack that I’ve only ever used once isn’t working |
Someone else had a look earlier and he’s fairly convinced it’s sticking actuators causing it.
