Home > General > Front end knock |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
If you drive at walking pace and tap the brakes, does it knock then? Would suggest lower front arm bushes.
Tue Oct 03 2023 4:12pm |
camel_landy Member Since: 05 Sep 2010 Location: Swansea Posts: 68 |
I had something similar... Eventually tracked it down to a 22mm impact socket, which the mechanic had left/dropped behind the front grille.
Thu Oct 05 2023 12:43pm |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 245 |
Update: car has been to the garage but everything seems tight. Had new arms etc. last year and don’t do many miles per year. Knock is still present, trouble is that it is so intermittent. |
Wed Oct 11 2023 11:13am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
Bad new wheel bearing? Not impossible. Seen new ball joints creak from having zero grease from the factory. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Oct 11 2023 2:43pm |
Strangely enough, I had both front bearings done about a year ago. Certainly worth investigating… |
Wed Oct 11 2023 2:47pm |
