Home > General > Front end knock
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Front end knock
I have an intermittent knock from the front. I can both hear it and feel it through the steering wheel when it occurs. It has only started recently, whether it is a coincidence that I had both front wheel bearings done and the arb’s is anybody’s guess. It was not there prior to the work being done.
Any ideas?
Post #636323 Tue Oct 03 2023 1:56pm
If you drive at walking pace and tap the brakes, does it knock then? Would suggest lower front arm bushes.
Or it could one of a number of things - track rod ends, steering lower joint. 2012 SDV6 - it's missing a couple of cylinders
Post #636325 Tue Oct 03 2023 4:12pm
camel_landy
I had something similar... Eventually tracked it down to a 22mm impact socket, which the mechanic had left/dropped behind the front grille. Laughing
Good luck, I hope yours is a 'cheap' to fix.
M
Post #636391 Thu Oct 05 2023 12:43pm
Salisburylander
Update: car has been to the garage but everything seems tight. Had new arms etc. last year and don’t do many miles per year. Knock is still present, trouble is that it is so intermittent.
Post #636519 Wed Oct 11 2023 11:13am
NoExpert
Bad new wheel bearing? Not impossible. Seen new ball joints creak from having zero grease from the factory. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636520 Wed Oct 11 2023 2:43pm
Salisburylander
Strangely enough, I had both front bearings done about a year ago. Certainly worth investigating…
Post #636521 Wed Oct 11 2023 2:47pm
