![]() | Home > General (L494) > Rear main seal - leak |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
I would assume this will be engine out, but don't know the seal type assuming one piece . M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
When you say rear seal do you mean the pinion seal? Mine too leaked and is a common fault with these cars. I got mine done via an aftermarket warranty but I think the cost was around £700. |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1193 ![]() ![]() ![]() |
gddmt, car just came back from a transmission service with ZF, and the tech, who used to work for JLR, tells me that the rear diff is leaking, probably the pinion seal again! |
Oh dear , seems like it’s a very common fault on these cars.. |
Turns out it was just a dislodged diff breather. While they were at it, I told them to change diff oil. Total cost: R 1,901.36 -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
